can anyone confirm that the blue wire is the live i need to cut and solder in another wire to use as the live trigger wire for my relay
TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread
Author | Subject: wiring for high boost fuel pump |
![]() Seasoned Pro ![]() Location: Inverness-Shire Registered: 19 Dec 2005 Posts: 7,459 Status: Offline |
i am in the middle of wiring and routing in my swirl potcan anyone confirm that the blue wire is the live i need to cut and solder in another wire to use as the live trigger wire for my relay ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
and can anyone recommend a live to use for going to the relay, as my main live for powering the bosch fuel bumpi have thick gauge wire at the ready one or two people mentioned using a live from back of ECU area ![]() a live on the fuel cut off switch perhaps? or run a live from battery (fused of course) hope this makes sense i wrote it in a rush ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
![]() aka Jim Davey ![]() Location: Southampton Registered: 01 Oct 2007 Posts: 8,648 Status: Offline |
You could take the power for the relay directly from the battery via a suitable fuse. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
![]() Seasoned Pro ![]() Location: hiding all receipts for car Registered: 09 Jul 2008 Posts: 11,901 Status: Offline |
sorry mate, can't help as rich fitted mine, I can look and take some pics though if you need any?I'm not sure where the feed for mine comes from. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
thanks Jim, confirms what Rich just pm'ed me ![]() i think i sorted both queries, thanks again though Andy. more time online to search and i found it straight away... simgti6 wrote: engine fusebox, fuse 9 (15amp) blue wire 121 is the fuel pump live this is the wire I used to power the relay for the bosch 044 pump ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
Just make sure you feed the open contact not the coil or the fuel pump will be constantly on.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
the "open contact" on the relay?i plan to use a 30amp relay as i already have one basically when my standard fuel pump kicks in it will trigger the relay to complete the Bosch 044 circuit thus both fuel pumps will go at same time. pretty sure i understand enough electrics to not blow anything up to use correct gauge wire, 30 amp fuse for the Bosch live wire coming from battery to relay will solder and heat wrap any wires so it does not look too rough this seem okay? ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
![]() (not mine, stole it off the internet) ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
![]() Seasoned Pro ![]() Location: Crowborough Registered: 22 Mar 2008 Posts: 3,445 Status: Offline |
Yup, thats how i'd do it ![]() ________________________________________ Black power baby! SUUUUUPERCHARGED![]() Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
thanks.________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
![]() Seasoned Pro ![]() Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
That blue wire goes right back to the maxi fuse box. Can't remember which fuse it is but its obvious if you look underneath because the blue wires there. You could splice into it there, attach the relay onto the maxi fuse box so it's protected and easy to get too, and also easy to run a cable from the battery, through the relay, then under the car to the new pump.The 044 pumps draw 14a at 5 bar, and 15a at 8bar, so probably a 20a fuse to be safe and avoid nuisance fuse blowing, or a 15a one should be ok but under heavy load the pump may blow it. As long as the cable your using is rated above 15a it should be fine. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
Thanks Pete, putting the relay in the fuse box sounds like a good idea.Should be easy to find that wire and solder/splice into ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
for anyone whos interested fuse 9 ; spliced it successfully ![]() ![]() relay located in fuse box with live running along next to abs wires to rear of car (havent secured these yet) both fuel pumps are priming okay. update : works great ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
