displaying posts 1 to 25 of 47
Author Subject: Down on power, potential fuel pump?
demondriverdan
The Rallye has seemed down on power since the heater matrix pipe popped off. The fuel pump also makes an unusual groaning noise in the morning when it primes for the first time (i.e. first time I start the car that day).
Any ideas? Thought it might be the fuel pump based on the noise.
Rallye Race Car
Posted 3rd Aug 2012 at 22:56
pugpower1986
poss head gasket on way out... as pipe popped off causing engine to overheat... its happened to me on my dturbo mate
98 Cherry Rallye
98 cherry 106 gti
Te@m Cherry Smile
Posted 3rd Aug 2012 at 23:08
demondriverdan
Hmmm, yea. It got to about 108c before I shut it off when the hose popped off, stop light wasn't on.
It's going into the garage tomorrow anyway to investigate a small power steering fluid leak so will ask them to have a look at the head as well. They reattached the hose so they know the situation.
Rallye Race Car
Posted 3rd Aug 2012 at 23:13
demondriverdan
Just been out and checked, no mayo on the rad cap. Will see what the garage says tomorrow.
Rallye Race Car
Posted 3rd Aug 2012 at 23:34
mattgti6phase2
108oC isn't a dangerous temperature stage 1 fans are 97oC so i wouldn't say it was anywhere near hot enough to warp the head unless however it was running for long with no water Dunno
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 4th Aug 2012 at 01:40
110 is when the stop light comes on.
Posted 4th Aug 2012 at 08:20
BlackSix
One thing i think you need to remember is that if coolant is coming out, air is going in and if the thermostat housing gets empty the temp sensor cant get an accurate reading because there wouldnt be any coolant to measure the temp of.
Posted 4th Aug 2012 at 11:18
mattgti6phase2
Mine reached a high temperature once, for some reason the fan didn't kick in Crazy it reached right up to the red line before i noticed and drove off to cool it down, never had that problem since. No stop light for me.
5 x a 306 owner!
Posted 4th Aug 2012 at 11:23
swiftyboi006
This is correct, it may have said 108c but it could have been alot hotter as it may not habe read accuratly
Black p3 Love
Posted 4th Aug 2012 at 13:16
demondriverdan
Cheers all. The garage are confident that it isn't the headgasket, tempted to get it in writing from them so that if anything happens soon-ish I might be protected (if that makes sense).
They've got the car until Monday to have a look over and find the issue.
Rallye Race Car
Posted 4th Aug 2012 at 17:46
BlackSix
have they tried pressure testing the coolant system?
Posted 4th Aug 2012 at 17:52
demondriverdan
They didn't when I was there. Will check to see if they have / are planning on doing it on Monday.
Rallye Race Car
Posted 4th Aug 2012 at 18:01
Get a sniff test done as well to be sure. Yes
Posted 4th Aug 2012 at 19:15
demondriverdan
On it Smile
Rallye Race Car
Posted 4th Aug 2012 at 19:24
When was the last time the fuel filter was changed? Unsure
Posted 4th Aug 2012 at 22:34
demondriverdan
I believe the car was serviced around 2-3k miles ago when the engine went in, that's what yippeekaye said anyway!
Rallye Race Car
Posted 5th Aug 2012 at 10:46
But did that service include a fuel filter though? Dunno
Posted 5th Aug 2012 at 10:47
demondriverdan
I don't know tbh. I'd hope it did but can't say for certain. Will definitely be jacking it up and checking when I get the car back!
Rallye Race Car
Posted 5th Aug 2012 at 10:58
Matt_rallye
Dan my fuel filter was also done 3k ago, looks shagged. Genuine pig filter going on mine.
Also if it's down on power it's worth checking the timing is still together, locknut up at bottom end and check the cams. I have a feeling mine was slightly out, and bottom pully had slipped round slightly. I know that your linking it to the heater pipe but you might have only just noticed it since its happened.
Posted 5th Aug 2012 at 11:37
demondriverdan
Garage says there's nothing wrong with the performance of the engine, diagnostics and a general inspection have come up ok. The only thing that they've found is that the throttle cable was a bit loose so wasn't giving full travel.
The aux belt tensioner is also very worn so they're replacing that. Roughly how much would people expect that to cost? They've given me a quote of £200 all in and worse case in terms of labour?
Not too keen on doing it myself, I like the road car to be looked after properly and I don't really have time.
Rallye Race Car
Posted 6th Aug 2012 at 11:23
The fact that you weren't getting full throttle travel will have had something to do with why it felt sluggish. Yes
As for changing the aux belt tensioner, I would say the part probably costs around £50, so with that in mind I wouldn't want to be paying anymore than £60-70 to have it fitted. It's fiddly, but not hard at all. Smile
Posted 6th Aug 2012 at 13:06
demondriverdan
They've quoted me £120 assuming the install is reasonably straight forward so sounds about right.
Rallye Race Car
Posted 6th Aug 2012 at 13:24
Is that for the part and labour then? Unsure
Posted 6th Aug 2012 at 16:06
demondriverdan
Yup, if the installation is reasonably quick.
Rallye Race Car
Posted 6th Aug 2012 at 16:16
It's not that bad to do really, just a bit of patience with a 13mm (preferably ratchet) spanner. Yes
Posted 6th Aug 2012 at 18:51
