displaying posts 1 to 25 of 56
Pages (3): [1] 2 3
Author Subject: Flat battery changed but now won't start! Key fob not workin
gb_gti6
My battery went flat so I took it off and charged it, now after putting it back on the car won't start just turns over.
The key fob is also not working after changing the battery.
Both car battery and fob battery are fine
Any ideas!!
Thanks
Team OCD
Posted 14th Mar 2012 at 20:39
Check the fuses under the steering wheel. I reckon one of the 5A ones has gone.
Does your interior light also not work? If so, it's deffo a fuse. Yes
Posted 14th Mar 2012 at 20:40
gb_gti6
Checked fuses, and the interior light does work still
Team OCD
Posted 14th Mar 2012 at 21:04
Ok, does the fuel pump prime when you turn the ignition on?
Posted 14th Mar 2012 at 22:38
gb_gti6
Sure it did but will double check the morning, what you thinking?
Team OCD
Posted 14th Mar 2012 at 22:49
Maybe you have dislodged the fuel pump relay when removing the battery as the relay is connected to the battery box. The other thing to try is press the fuel cut off switch in the engine bay (big red button at the rear of the bay near the passenger top suspension mount). It could be when you removed the battery you knocked this and because it is an inertia switch it killed the fuel supply to the rail.
Posted 14th Mar 2012 at 22:54
gb_gti6
It's not the fuel cut off switch I have already tried that but haven't looked at the relay where abouts is that? I have been trying to narrow it down as I normally quite good but this has got me and is starting to get annoying! Thanks though.
Team OCD
Posted 14th Mar 2012 at 22:58
No problem.
The relay bolts to the back of the battery box with an 8mm nut. If your fuel pump primes though this won't be at fault. So, your next step is to check if the fuel pump primes. If it does, you need to see if its fuel or spark you're not getting.
I suspect its spark you're lacking, and thats possibly because the ECU hasn't been unlocked as your keyfob isn't working. Have you got another key to try?
Posted 14th Mar 2012 at 23:03
gb_gti6
Yeah I know the relay you mean now, I have only got one key and the fob worked fine before! Surely you can change a battery without needing a unlocked ecu lol. Had this prob with another one I had but that didn't turn over or anything but was sorted the minute I changed the ecu.
Team OCD
Posted 14th Mar 2012 at 23:07
Yes, the ECU should be fine. I was just asking in case you could try another key and eliminate that from questioning.
So, its finding fuel or spark problems. One culprit could be the crank sensor. These have a tendancy to just randomly fail completely without warning which is rather annoying. When you say your key fob doesn't work anymore can you still lock and unlock the car by turning the key in the doors? And if so, does the central locking operate properly when you do this?
Posted 14th Mar 2012 at 23:14
gb_gti6
Funny you ask that it would appear the key is different to the door lock as though the ignition barrell has been changed maybe which I wasn't aware of when I bought it. The key only works in the ignition, doesn't work with door locks or glovebox which I only found out earlier!
Team OCD
Posted 14th Mar 2012 at 23:17
You need to check for a spark tomorrow when its light. I am pretty sure you are going to find you don't have one.
IF this is the case then my next step would be to disconnect the crank sensor and check its resistance to see if this component has failed.
However, for some reason, the fault thats going round my head is that you've got an immobiliser issue which is killing the spark.
Posted 14th Mar 2012 at 23:24
gb_gti6
I think you maybe right after previous happenings. Everything was ok until the battery went flat, so if it is a immobiliser problem then the easiest way to sort would be to get an unlocked ecu? Or any other way?
I never seem to have time at the minute to do much!
Team OCD
Posted 14th Mar 2012 at 23:30
If it is the immobiliser you could get an unlocked ECU although yours should be able to be sorted out.
Check to see if the fuel pump primes first, then we can go from there. Smile
Posted 14th Mar 2012 at 23:38
gb_gti6
Ok will do thanks, will let you know
Team OCD
Posted 14th Mar 2012 at 23:40
No problem mate, keep me informed. Thumbs up
Posted 14th Mar 2012 at 23:42
Any update on this? Have you checked on the fuel pump priming?
Posted 15th Mar 2012 at 10:41
gb_gti6
Hi, I have checked and fuel pump is defo priming and the relay was fine!!
Team OCD
Posted 15th Mar 2012 at 19:05
I'm pretty confident in saying thats an immobiliser issue, and for that reason you're getting no spark. Yes
If you sit in the car with the doors closed and press the driver's door lock pin down does the central locking activate, or does it only lock the door the door which you have pressed?
Posted 15th Mar 2012 at 21:44
gb_gti6
I am sure it is aswell I had this issue with both I have owned can't understand why this happens!!
It just locks the one door.
Team OCD
Posted 15th Mar 2012 at 21:51
Have you definitely checked ALL the fuses under that steering wheel?
There is a 5A fuse there that runs the central locking AND the immobiliser. My guess is that it has blown and that is why neither appear to be working...
Posted 15th Mar 2012 at 21:53
gb_gti6
I can check again but I am pretty sure they all fine, I could maybe try another one in it to rule it out completely but have checked!!
Fuse 6 if I am right?
Team OCD
Posted 15th Mar 2012 at 22:15
I can't remember the fuse number off the top of my head, but it sounds about right...Yes
How did you check the fuse? If it was just a case of pull it out and visually check, sometimes they don't blow in such an obvious way. This is why it is better to get a multimeter and check across the pins of the fuse for continuity. That way you know for sure whether the fuse is good or not.
Or alternatively, with the ignition on, check if you have 12v at one side of the fuse and then if you have, see if you've got it at the other side of the fuse relative to Earth. Smile
Posted 15th Mar 2012 at 22:20
My thinking behind this theory is that it has been known for these fuses to not like being connected to a full battery once they have been disconnected from power, and hence they can blow.
The fact that the central locking AND the immobiliser has packed up makes sense as they are on the same circuit. And the weak part of that circuit is the fuse.
Posted 15th Mar 2012 at 22:22
gb_gti6
I just did a visual check if I am honest, have a stack of fuses so I will try that and will try with multimeter if that fails and then go from there!!
Is there an easy fix without buying an unlocked ECU if it this?
Team OCD
Posted 15th Mar 2012 at 22:24
Pages (3): [1] 2 3
