Author Subject: Chequer plate
Has anyone used aluminium chequer plate in their footwells?
Did Snetterton yesterday, and the inside of the car gets extremely hot, and most of this is coming from the driver's footwell where (now all the deadening has been removed) is really does get extremely hot.
Not only that, I still have a few Paul Walker-style manifold breaches in the floor where the tar crap has been removed and the plastic plugs have gone missing.
I reckon best bet is to get some aluminium chequer plate stuff that I can shape to where I need it - it'll help keep out the heat, plug the holes and provide some grip. So, two questions:
1) There are various thicknesses, thinnest seems to be 1.5mm. Does anyone know if that's thin enough to bend to shape? Obviously want it to be as light as possible as well.
2) Does anyone know of someone who does it cheap other than eBay? It's the kind of thing I can imagine is marked up considerably and can probably be found at some tiny company in some nowhere industrial estate for no money
Cheers in advance people.
Posted 20th May 2011 at 13:34
gti6dave
You'll be able to bend that fine, you can always run an angle grinder down through behind where you are bending to make it easier.
I would try at a local fabrication place, they would probaly have a few offcuts lying around that would do the job
Team Supercharged
Email:
davebrowse@hotmail.com
Posted 20th May 2011 at 14:46
i've got a footwell template here for the cnc machining company next door. they were going to knock me up a couple of textured sheets in satin black for my footwells. good call for reminding me to chase them up
hope this helps
Posted 20th May 2011 at 15:04
Yeah Rikky that's a massive help, ta LOL
Cheers dave, good call on the grinding. Which incidentally I heard Rikky's into.
Posted 20th May 2011 at 15:08
will130787
Yes
It will be a pain in the arse to bend into shape imo
Also how will you secure it?
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 20th May 2011 at 16:56
bond it down or get some steel sheeting like i intended and you could spot weld it down. or rivet it!
Posted 20th May 2011 at 16:59
I was planning on rivetting it, simplest way I can think of and makes for easy removal.
As for neatness I'm not that fussed, as long as it's about right and provides some protection I'm not all that fussed.
Posted 20th May 2011 at 17:00
will130787
Trouble with rivets would be corrosion from the underneath? Rivet then seal underside?
Posted 20th May 2011 at 17:07
tigerseal but check heating temps, don't want it working loose under heat
Posted 20th May 2011 at 17:08
Tigerseal would work, if it doesn't show I've previously just slapped some hammerite around the hole too which seems to work.
Posted 20th May 2011 at 17:11
How about this?
Posted 20th May 2011 at 23:37
I saw those and they're an option, but was hoping for something less than forty quid. Seems a lot to me...
Posted 21st May 2011 at 00:39
I know you would rather buy the sheet and make it, but if it stays at £25, will probably be worth it Yes
Posted 21st May 2011 at 02:50
chris with a pug
I used checker plate on my floor. And I went for the cheap option and stuck it down with gripfil lol.
I cant remember where I got it from but it was 1.5mm I will see if I can find the invoice
Posted 21st May 2011 at 03:15
Better off bonding it down, or at least a bead of adhesive and then rivet it down, otherwise you'll probably find the rivets come loose as it settles in from the bends/heat/vibration.
Then it'll do your tit's in 'cause it'll rattle.
You'd be better off with thinner stainless steel rather than thick ally plate.
Posted 21st May 2011 at 03:36
to summarise: rikky was correct Whistle
Posted 21st May 2011 at 04:52
midlife
lol
Cool
Team 330™Cool
Team "no front end or engine"
Posted 21st May 2011 at 05:09
Had to happen one day Whistle
Posted 21st May 2011 at 05:10
£13 delivery as well mind Yes
Posted 21st May 2011 at 14:54
phillipm wrote:
you'll probably find the rivets come loose as it settles in from the bends/heat/vibration. Then it'll do your tit's in 'cause it'll rattle.
True dat, just didn't want anything too permanent. I'll figure something out.
Why so? I'm happy to go for that if there's something suitable, just want something that provides some grip too if possible. Open to suggestions Smile
Posted 21st May 2011 at 14:55
Harder wearing, easier to bond in, being thinner it should be easier to bend, and it has a lot less heat transfer than ally Thumbs up
Posted 21st May 2011 at 15:35
Can't argue with that kind of logic! Any thoughts on where to get it or what kind of thickness I'd need?
Posted 21st May 2011 at 23:08
Have you thought of just getting some better heat reflective material in the exhaust tunnel? I found most of my heat came from the tunnel anyway so sheeting in the footwells is'nt going to help that much. A load of exhaust wrap and a good polish up of the existing heatshields would be much more effective. If you need a little extra grip, use skateboard grip tape cut in strips in the footwells, great on slippy drilled metal pedals too incidentally.
Posted 27th May 2011 at 02:11
Hadn't really thought of that no, but i'll do that as well.
Skateboard tape is also a good call.
Posted 27th May 2011 at 02:30
i have a 3metre x 600mm length of griptae i bought off a lad on one of the 106 owners clubs after seeing it in the footwell of his car a couple of years ago. still not fitted it!
Posted 27th May 2011 at 03:18
