Thanks
Stewart
Author | Subject: Radiator Bottom Hose O-ring |
christie-rs
Newbie Location: Aberdeenshire Registered: 04 May 2011 Posts: 7 Status: Offline |
Hi where is the best place to get the o-ring for the bottom hose that goes in to the radiator, just phoned up my local pug dealer and they said it was £64.Thanks Stewart |
Posted 11th May 2011 at 20:58
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,824 Status: Offline |
you'll get it from peugeot for about £3 iirc.I'd bet £64 was not for the bottom hose even, as they are only £29. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 11th May 2011 at 21:01
christie-rs
My bad I'm a donkey, just phoned them back up again they said it was 64p not £64 |
Posted 11th May 2011 at 21:17
Seasoned Pro Location: The Nam Registered: 24 Jan 2006 Posts: 12,828 Status: Offline |
Make sure its the right hose as there are differences over the range.________________________________________ Nothing to see here |
Posted 12th May 2011 at 14:47
yup, there's 3 hoses for a 6 dependent on age, though the later 2 are the same each end and use the same o-ring (with the steel wire clip in the rad), just different moulding and clips in the wheelarch, also cheaper ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 12th May 2011 at 15:23
christie-rs
Yeah im gonna bring the old o-ring with me to make sure its the right one. |
Posted 12th May 2011 at 15:26
taking the old hose would be better, as the o-rings are quite close in size.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 12th May 2011 at 15:36
rikky
🦔 Location: cheshire Registered: 28 Feb 2004 Posts: 26,794 Status: Offline |
do yourself a favour and get 2.. i kept ripping mine trying to fit it ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Posted 12th May 2011 at 16:26
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Only available in packs of ten at all my local dealers handy to have a couple spares though________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
Posted 19th May 2014 at 14:10
you mean they come from warehouse to dealer in packs of ten and they don't want them on the shelf so they try and make you buy all of them.mean bas**rds. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 19th May 2014 at 14:11
Particularly if it's the early type without the metal clip I usually put a bit of silicone round it as 1 it helps it slide in easier and 2 it will help make a better seal as their always a weak point to be honest. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 19th May 2014 at 14:33
I hate it when people do that as it makes it an utter c**t to remove.not needed if you use a new hose/o-ring. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 19th May 2014 at 15:02
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
silicone grease would be betteri hope you didnt mean silicon sealant as in the bathroom stuff |
Posted 19th May 2014 at 15:31
jeffers
Forum Admin Location: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
cully wrote: silicone grease would be better i hope you didnt mean silicon sealant as in the bathroom stuff Better with 'red rubber grease' keeps the seals supple despite the changes in temperature. ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Posted 19th May 2014 at 22:26
jeffers wrote: cully wrote: silicone grease would be better i hope you didnt mean silicon sealant as in the bathroom stuff Better with 'red rubber grease' keeps the seals supple despite the changes in temperature. This is what you want buzzbrightyear has attached the following image: ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Posted 20th May 2014 at 00:41
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
That seal is deffo under a quid, I bought 2 recently.Having just suffering enduring pain with this pathetic arrangement, I was meticulous in the rebuild of it the last time and it seems ok atm. There are subtle differences in the lower hoses, I thought I had a picture. The 02 Xsara hose I had inadvertently fitted had much shallower prongs, with a much less pronounced shoulder for the metal spring clip to sit against. I replaced this with my original 99 Rallye hose, which i'd wire brushed to remove all corrosion from. I fitted a new genuine rubber seal from Peugeot, which was a nice snug fit off the car. It took some leverage to fit when on the car but it went in nicely, and the clip fitted fine. I had, of course, disconnected the hose from its two carrier clips on the inner wing and had pulled it from the connector on the back of the engine, ensuring no undue influence. I concur with Mei that no lube is needed, I can only envisage it making things worse - that seal will find it's own snug fit. Be careful that it is a good fit on the pipe, else it only serves to roll over when being inserted. ________________________________________ I'm Si btwNight Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
Posted 20th May 2014 at 14:19
stan_306gti6
Forum Admin Location: Kent Registered: 18 Jan 2004 Posts: 21,768 Status: Offline |
I would suggest the use of the red rubber grease when fitting this though - makes it slide in much easier and avoids damaging the seal, which you really don't want as you'll only find out it's damaged when it leaks after you start the engine. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Posted 20th May 2014 at 23:30
