When the button is pressed there is a “click” from the fusebox area but the button doesn’t light up or the rear screen clear
I just want someone to tell me it is simple to fix!
Thanks if you can help
displaying posts 1 to 25 of 28
Author | Subject: Rear demister not working |
![]() Regular ![]() Location: Purley Registered: 15 Jan 2004 Posts: 483 Status: Offline |
I've just bought a new GTi-6 and the rear demister isn’t working ![]() When the button is pressed there is a “click” from the fusebox area but the button doesn’t light up or the rear screen clear I just want someone to tell me it is simple to fix! Thanks if you can help ![]() |
![]() Seasoned Pro ![]() Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
Is there any illumination on the switch at all?________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
simonjames wrote: Is there any illumination on the switch at all? It flashes momentarily but doesn't stay on ![]() |
![]() Senior User ![]() Location: Yorkshire Registered: 20 Jul 2005 Posts: 943 Status: Offline |
its the fuse/relay - had this on mine last winter - thugpuggin helped me out so he'll know which one you need________________________________________ Recommends:'mechanical_repairs' - Leicester 'miles' for suspension & Grp N/A goods Baker BM Mounts |
james_geldart wrote: its the fuse/relay - had this on mine last winter - thugpuggin helped me out so he'll know which one you need I will ask him when he collects my old car ![]() |
![]() Seasoned Pro ![]() Location: Livingston Registered: 08 Apr 2009 Posts: 1,042 Status: Offline |
Mine does the same, any further info on which fuse? |
![]() Seasoned Pro ![]() Location: Bristol Registered: 10 Apr 2004 Posts: 26,784 Status: Offline |
misschief wrote: Mine does the same, any further info on which fuse? Phase 3 fuse 7 30A and 22 Phase 2 fuse 5 and 27 The relay is the large Orange one with 9619879180 on it. ![]() ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Magic, cheers mate. |
Can I get the relay from halfrauds? Might pop down this week. |
![]() Seasoned Pro ![]() Location: Reading Registered: 24 Sep 2009 Posts: 3,933 Status: Offline |
misschief wrote: Can I get the relay from halfrauds? Might pop down this week. Yes, although you might find they only have a 30 amp rather than 25 ![]() ________________________________________ Ex Astor 6 owner![]() Also an Ex owner of a Bianca 6 ![]() Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... ![]() Now driving Mk5 Golf GTTdi, mile muncher But still live for the 306 ![]() |
![]() Seasoned Pro ![]() Location: Oswestry Registered: 01 Nov 2009 Posts: 3,132 Status: Offline |
thugpuggin wrote: misschief wrote: Mine does the same, any further info on which fuse? Phase 3 fuse 7 30A and 22 Phase 2 fuse 5 and 27 The relay is the large Orange one with 9619879180 on it. ![]() Excellent info ![]() Mines dodgy ![]() ![]() ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Went to halfrauds, guy behind the parts counter said they don't stock them. I've checked the fuses, they're both fine. One thing I did notice though, how the f*ck to you taker the existing relay out? Don't want to break it in half but I tried squeezing, turning, cursing etc but it was stuck. |
![]() Seasoned Pro ![]() Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
Just have to wiggle it out, will be tight as probly never been out before!________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
![]() Seasoned Pro ![]() Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
i got this fault with my rear demister,it wont light up on the switch but will light up when the lights are on.but it doesnt stay on.i have checked me relay and found out it has failed and burned the connecter out were the relay goes into.so what is that part called that the relay goes into. is it called a base? any info would be gratefull |
![]() Seasoned Pro ![]() Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Do you mean the contacts in the relay panel itself? In that case you would need to clean up/re-solder/replace the burned out contacts. Good idea to pull all relays and fuses one at a time, clean contacts as they get corroded with cars sitting outside in the weather all the time and things being generally wet corrosion builds up, which increases resistance, which makes the contacts and relay get hot, and eventually burns things out. Even just unplugging and replugging helps contacts conduct current better as it scratches the contact metal slightly cleaner. First step to check if correct relay fitted: my rear demister only worked if button held in with finger, when releasing it light went out. Turned out a PO had replaced the orange relay with a green one (standard on/off relay). A replacement orange one (correct orange relay has 10 - 12 minute timed delay) fixed the problem. ________________________________________ Cherry Rallye SOLD |
![]() Senior User ![]() Location: Halesworth Registered: 10 Jan 2007 Posts: 636 Status: Offline |
Where can I get one of these said orange relays? ________________________________________ Astor 6 |
I got mine second hand off here. Or try Pug - can't be that expensive. ________________________________________ Cherry Rallye SOLD |
I have changed the relay which cured the problem used the demister about twice and it's stopped working again, I assume it's the relay again, anything else I should check before putting another relay in it? ________________________________________ Astor 6 |
Just went and pulled it out and it has melted number 3 termal again![]() ________________________________________ Astor 6 |
Got a few if needs be. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Even if I just changed it to another new relay it will probably just melt that one too?________________________________________ Astor 6 |
Ed_van_dijk wrote: Even if I just changed it to another new relay it will probably just melt that one too? Was the relay you fitted second hand? ![]() If so could have been used alot,I would try new ![]() ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
![]() Capt Pedantic ![]() Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,851 Status: Offline |
£25 new________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: £25 new Ouch.Thats from Pug? Need one for mine too,second hand one has lasted a while though ![]() Might search relay part numbers see if available anywhere else except Pug ![]() ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
