TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2
Author | Subject: fuel pump wont stop priming ? |
![]() ![]() Location: galway/ireland Registered: 24 Feb 2009 Posts: 628 Status: Offline |
my fuel pump wont stop primimg its self even when i have the key out of the ignition it still primes its self ![]() ![]() ![]() ![]() ________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 ![]() |
![]() Seasoned Pro ![]() Location: Essex Registered: 20 May 2009 Posts: 9,185 Status: Offline |
It's being prepared, it was probably in the scouts ![]() Have you done anything funky with the radio wiring that could be shorting the ignition live to the constant live? There's a short between the two somewhere by the sound of things. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
![]() Seasoned Pro ![]() Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Mine does this too. Has done it ever since my ECU died and had an unlocked one as a replacement.Doesnt seem to of caused me any problems, but still something that concerns me. ________________________________________ Chris1999 China Gti6 Supercharged ![]() 2000 Bianca 306 Diesel [Work runabout] |
![]() Seasoned Pro ![]() Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
![]() Definitely does this independent of the ignition electrics |
gilesy wrote: ![]() Definitely does this independent of the ignition electrics Yeah same ![]() Don't know how many times it does it, but have noticed it doing when key is not in ignition and also sometimes when car is still locked. ________________________________________ Chris1999 China Gti6 Supercharged ![]() 2000 Bianca 306 Diesel [Work runabout] |
And everyone's okay with this...? ![]() Where's all this extra fuel going?! No wonder BP are minted ![]() ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
Well my thinking is that its not releasing fuel outside of the vehicle, only pressurising the system. Its not on constantly.So I've left it! |
Man I've got to get round to some of your houses and tap into some of fuel lines you're keeping primed for me! ![]() I'm imagining these pumps priming 24 hours a day and big comedy cartoon bulging pipes everywhere, I do hope I'm not disappointed. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
I did think that when it primes it just gets pressure up to spec?If it was pumping fuel to the engine, would I not get a big backfire on starting the car if there was excess fuel? ________________________________________ Chris1999 China Gti6 Supercharged ![]() 2000 Bianca 306 Diesel [Work runabout] |
Correct, it'll only build up pressure to the injectors, which can't spray it into the engine without the ECU doing its thing. I suspect if it just filled your engine with petrol you'd know about it when the first spark occurred ![]() ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
![]() Capt Pedantic ![]() Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,847 Status: Offline |
they have such things as fuel pressure regulators, and fuel return lines.if its constantly doing so then check that the fuep pump relay is not damaged. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
![]() Regular ![]() Location: under the bonnet Registered: 07 Jun 2010 Posts: 115 Status: Offline |
this must be a catchy disorder my car keeps doing this now ???????????![]() ![]() ________________________________________ yeah the zx td is back on the road front mounted intercooler fitted fuel pump tweaks now required + turbo adjustment |
![]() Seasoned Pro ![]() Location: Norwich Registered: 29 Apr 2009 Posts: 1,966 Status: Offline |
mine does it once when i turn it off and take the key out.... or at least i think thats what its doing... doesn't do it all the time tho.________________________________________ Team SUPERCHARGED![]() ![]() Old Project thread Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url = |
![]() Seasoned Pro ![]() Location: Wiltshire Registered: 24 Jan 2010 Posts: 2,365 Status: Offline |
I had this problem on mine a while back along with The engine running/reving on its own with the keys out of the ignition! ![]() ![]() ![]() ________________________________________ I Live for the 306![]() TEAM CHERRY PINK RALLYE 2008 BMW ///M 320d |
![]() Newbie ![]() Location: Telford Registered: 06 Apr 2010 Posts: 43 Status: Offline |
I've had this problem since owning the car. Every so often, the car will be parked and locked, and I'll hear it prime. No idea how much it does it when I'm not there, but it seems to stop after the car hasn't been driven for a while.It didn't seem to be doing any harm, so I left it rather than chasing another electrical gremlin! |
![]() Seasoned Pro ![]() Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Is it not working as a fuel cut off? My pump goes through the motions of priming just as the car is turned off________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
![]() Regular ![]() Location: peterborough Registered: 18 Sep 2007 Posts: 195 Status: Offline |
mines done it for 3 years now, even after crashing it, when people ask what the noise is i tell them its the cool down of the after burners!!________________________________________ whatta beast! |
gti6mark wrote: mines done it for 3 years now, even after crashing it, when people ask what the noise is i tell them its the cool down of the after burners!! ![]() ![]() ![]() my rallye is still doing it some morning im gonna look out that window and all im gonna see is soe guy givin me the finger as he drives off ![]() ________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 ![]() |
