Author Subject: remote central locking upgrade
loftlex
Hi
the range of the remote locking on my phase2 td is poor to say the least, i have to be at the side of the car for it to work,,
so i am going to buy an after market remote locking kit off ebay,
anyway i am just after a heads up about where is the best place to locate the unit, i think the passenger footwell is the best place, but is the wireing i need there?
also does anyone know what colour wires i need to solder the unit too?
if not i will have to dig out my haynes manual and try and figure it out Smile
GTI wanna be Sad ---In a puff of black smoke and a whistle,,, i was gone Smile
Posted 17th Sep 2010 at 15:42
footah212
I just got myself a ph2 6 too. I was convinced the key fob batteries were goosed when the range of Central locking was poor.
Then i remembered my 'M plate; 306 XSI had the sensor located facing to the rear of the car.
When i use the fob from the rear or side it works cool. Does not seem to work from the front.
Replaced the batteries anyway(£4 from ebuyer) made no difference
This is only my opinion, i may be talking c**p. May save you some cash though
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 19th Sep 2010 at 02:59
loftlex
i got an after market keyless entry system of the bay for £9,,, lol, so i will fit it and see if its any better,,, got to love ebay Smile,, still need pointers on wire colours and location though Sad
Posted 19th Sep 2010 at 04:00
dan_s16
The reason ph1 and ph2 remote central locking range is crap is because infra red system was used i.e it needs line of sight to work. where as others use radio waves.
Loftlex: The central locking control unit is under the drivers side rear bench. Lift the lower section up and under the backrest there is a recess with a load of wires under there. I can't remember off the top of my head which wires are which but I'll try and let you know once i've found my diagrams.
Posted 19th Sep 2010 at 05:16
loftlex
thanks dan_s16 i have been looking at the haynes manual, but i cant make heads or tails of it,, lol,, when i fitted these to my old escort and my astra i was able to grab all the wires i needed from the passenger side footwell or just above the fusebox,, but finding the right bundle of wires was a right pain in the ass Sad
Posted 19th Sep 2010 at 13:42
loftlex
i got the kit today and the manual,,, or piece of paper,,,, is not very informative to be honest,, i need some pointers on where to fit it and where is the best place to get at the wiring looms Sad
Posted 22nd Sep 2010 at 01:41
dan_s16
Sorry I completely forgot to check, let me find the keys and i'll get some pics
Posted 22nd Sep 2010 at 18:48
dan_s16
Pull the rear seat base up behind the drivers seat and you should see something like this:
A closer view of what we are looking for, this is the central locking unit in phase 1s and 2s:
Unplug the black and the white plug and gently pull them towards you a little. Excuse the insulation tap covering the joints in the wires, I was rushing around installing the alarm system and ran out of heat shrink for the last 2 wires I had to join and haven't got round to redoing them properly yet (on my to do list now I've been reminded about it).
On the black plug there should be 2 pins with 2 wires coming out of each, on mine one set is orange and one set is purple, the may be different colours and have different numbers on a phase 2 but they should be in the same location. The orange ones (closest to the end of the plug) are the lock and purple are the unlock.
If that doesn't help copy the instructions to me and i'll see if I can work it outSmile
Posted 22nd Sep 2010 at 19:36
loftlex
bloody hell thanks Smile
the instructions are a joke,, ill get a pic and show it to you Smile
loftlex has attached the following image:
Posted 22nd Sep 2010 at 20:14
loftlex
the system is a KD205/KD29 or a MN205, they are all the same unit,, and i have contacted 2 diffrent websites that sell them,, but still have had no fitting instructions as yet,,,
has anyone ever fitted one of these?
Posted 25th Sep 2010 at 03:36
loftlex
just had a reply from the manufacturer in china,,, they sent me the same inforamtion that i all ready have,, with no extra wireing guide for the central locking,,
looks like i have fecked up Sad
bugger Sad
Posted 25th Sep 2010 at 14:23
smegal
Could you post a bigger copy of the instructions up.
Ex SC-6
Now in a Megane R26
Posted 26th Sep 2010 at 04:28
loftlex
i found a ebay seller with the same unit as me for sale,, and they posted their instructions Smile
many thanks,,,
just one thing,, is the common as its negative triggered earth?
its seems logical,,, but then again i am wrong 50% of the time,, lol
Posted 26th Sep 2010 at 18:49
loftlex
i tried downloading the image and uploading it on to here,, but i keep on having to resize it and the image gets too small to see,, so here is the ebay link http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290476689003&ssPageName=ADME:X:RTQ:GB:1123
Posted 26th Sep 2010 at 18:52
dan_s16
I've had a look and I have a couple of options:
1st one is to try wiring it up so that the new system triggers the original central locking but this will require some testing to see which central locking wires do what in the new system. They should be wired so that it can control 3 solenoids, you need to find out which one is positive when locking and which one is ground. This needs to go to the orange wire above and then the one that goes positive on unlocking needs to go to the purple one above. However i'm assuming that the standard central locking uses positive pulses to operate and not ground pulses. I will try and check on mine when I have a spare 5 mins. If that hasn't made any sense don't worry I'll explain it better when I have some time later.
2nd option is to completely by pass the standard central locking and use the new system to operate the solenoids in the doors/boot.
I think either way you will lose the deadlocking though.
Posted 26th Sep 2010 at 21:22
dan_s16
From what I can see, you would have one solenoid across the brown and blue wires, one across the yellow and grey and one across the green and yellow/black wires.
When you lock it, the brown wire would be positive and the blue ground. When you unlock it the blue will be positive and the brown ground.
I'm assuming thats how it works but the colour pairings could be different.
Posted 26th Sep 2010 at 21:26
loftlex
Many thanks for taking time out to try and help me Dan_s16 and smegal, and every one else who had a look,, have a look at the new diagram on this on ebay link:
from my understanding providing the top diagram is negative or positive,,depending on the common line,,(i hope it is)
blue is lock
green is unlock
yellow+yellow/black goes to "common line"
i presume this is earth seeing its a negative system
and if it was a possitive system then i would have to connect this to +12v
am i right? lol
Posted 27th Sep 2010 at 13:07
loftlex
i get my car back on tuesday so i hope to get it installed tuesday afternoon Smile
Posted 26th Sep 2010 at 22:23
stage-auto
did we have any luck on establishing if the standard central locking is a possitive or negative system?
Posted 2nd Dec 2010 at 19:04
