Author Subject: piston cut outs?
309btcc
**DODGY SELLER**
anyone know somewhere i can get this done??
Posted 7th Sep 2010 at 01:01
rallyeash
welshpug had some done iirc
309 3dr K20 Type R
Posted 7th Sep 2010 at 01:05
Woodmill engineering are local and could do this, you will need to centre dot the datum point for the cut out by using an old valve cutting off the head and grinding it to a point. The head will need stripping and all the valves will have to come out to allow you to centre dot the top of all the pistons. With the piston 1 at TDC (Do each one in turn) put the sharpened valve in each of the four empty valve holes with the point down and give the tip a very gentle tap with a SMALL hammer, this will accurately mark the reference point for the machinist to enlarge your cut-outs, don't just get him to use the existing cuts as a reference as looking at the witness marks where tappers hit the pistons the cut-outs seem to be in slightly the wrong place anyway (too far towards the chamber wall as the valves hit the inside edge of the cut out)
You then need to repeat the process for pistons 2,3 and 4. Radial clearance (The gap from the outside edge of the valve to the side of the cut-out needs to be at least 1mm and the depth wants to be a good 1.5mm from the underside of the valve to the bottom of the cut-out. Mark inlet and exhaust positions on the pistons before you remove them as it will be a pain if you forget which one is which once you have them out. The macinist will also need to know the inclination angle of the valves so he can set the cutter at the right angle, make sure he uses a round nosed cutter as you don't want a sharp edge at the bottom of the cut-out to form a stress point.
Oh f*ck it, I just remembered you picked up those Omega high comp pistons did'nt you? You won't need any of the above info now!
Posted 7th Sep 2010 at 03:48
or just send them to martin price or sandy brown who have jigs to do this already Big grin
Posted 7th Sep 2010 at 04:14
Yeah, that's probably a lot easier Razz LOL
Posted 7th Sep 2010 at 04:17
I will admit to having cracked the dremel out once and done them freehand for a V6 set on a budget*...LOL
*The above advice is not endorsed or recommended by the user, and damage is your own bloody fault for trying to copy me being a pikey, I accept no liability for you being a lesser pikey.
Posted 7th Sep 2010 at 04:18
Laugh my ass off
Posted 7th Sep 2010 at 04:19
Pikey masterclass 101 LOL
Posted 7th Sep 2010 at 04:21
You can also braze a lathe insert to a couple of spare valves and do it in-situ with a stop on the valve stem* Whistle
*Previous disclaimer applies
Posted 7th Sep 2010 at 04:24
Are you going to have to travel the country killing us all now that you are revealing all this classified info? Unsure Wink
Posted 7th Sep 2010 at 04:27
I'm afraid I'll have to, top secret race info that, better sort out your affairs.
Too late for that, I'm leaving my unfinished project to the forum at large, good luck fellas Dry
Posted 7th Sep 2010 at 04:30
Shit, now the whole forum's gonna get sucked into a blackhole for credit cards...LOL
Posted 7th Sep 2010 at 04:31
A problem shared...Dry Razz
Posted 7th Sep 2010 at 04:34
All that'd happen is the entire forum would be locked in a battle about whether it should be 30mm lower or 40mm lower, and spend 2 years shouting c*nt! at each other, whilst rallyestyle fitted some dodgy LED front running lights so it looked faster...
Posted 7th Sep 2010 at 04:37
Probably! If you attack my Wossners with a Dremmel I'll come back and haunt you Angry
Posted 7th Sep 2010 at 04:39
Hmm
Posted 7th Sep 2010 at 04:42
phillipm wrote:
Hmm
Step away from the power tools, I went over em and could'nt find a sharp edge or a bit of spare ally on them anywhere Wink
Posted 7th Sep 2010 at 04:45
I'm sure they could be lighter....LOL
Posted 7th Sep 2010 at 04:50
Definitely, but would they still be reliable? And I don't mean could I rely on thm to fail? Razz
Posted 7th Sep 2010 at 04:52
pfft, it's not fun unless every time you head towards the redline you start watching for dents in the bonnet.
Posted 7th Sep 2010 at 04:56
True, it's the acompanying dents in the bank balance that ruin the fun for me though...
Posted 7th Sep 2010 at 15:24
