displaying posts 51 to 75 of 621
Pages (25): first .. 2 [3] 4 .. last
Author Subject: 205 2.1 16v rallye track car
rallyeash
Post #51
thanks,
ive been working on an alternator setup as i believe the standard pug one is way overkill just to run the lights, and tbh i never really drive it at night anyway, so they get hardly used.
one alternator from a kubota diesel engine, atleast half the weight.
side by side both with pulleys removed, the kubota one runs a A section V belt and the pug setup is a multi grooved belt.
the pug pulley fouled on the back of the alternator, so i sliced the back off the pulley...
ill be giving the pulley to a mate whos a machinest that can skim the back of the pulley so its completely true, although i cant see any wobble in the pulley!
pulley fitted to the alternator, shaft size exactly the same size! all spins fine
alternator hung from the a/c mounts. keeping the weight nice and low.
above view, i know the pulleys currently dont line up, i need the top hat type spacer that sits in the a/c holes. i think this will space the alternator across enough to bring in line
next job was to try and get a belt sorted, i thought to try fit the standard one on there and to my luck it fitted, so im going to go to a belt supplier and get a 3 rib belt not a 4 rib one so the belt isnt running on the end of the pulley because now theres now lip.
all thats left to do is, get the gti6 a/c bush, make up and adjuster which im going to get a threaded rod, two rose joints and a barrel nut in the middle to adjust it all. probably in M8 (just so happens we keep the above at work!) and the belt.
309 3dr K20 Type R
Posted 2nd Jul 2010 at 23:55
309btcc
**DODGY SELLER**
Post #52
nice save even more weight
Posted 3rd Jul 2010 at 00:19
jeffers Forum Admin
Post #53
Really nice build this, have you got the bush you need mate or not?? if you need them i've two at the min as i removed my aircon compressor from my track car recently and kept the bushes, as they looked like they may come in handy! Roll eyes Yours for postage should you need them! Wink
Team Running Engine again!
Team Negative Camber!
Posted 3rd Jul 2010 at 01:53
rallyeash
Post #54
thanks, yeah ive just rumaged through the garage and found one, atleast i think its one.. if it isnt ill give you a shout Smile
309 3dr K20 Type R
Posted 3rd Jul 2010 at 01:59
dj_turbo
Post #55
I run somthing similar on mine ash it was from a fork lift truck i got mine from. This may be of help theres a alloy (nice and light) ribbed pulley on ebay think it was ment for a mazda thats a direct fit on the denso alternator and is for a 5 rib belt i just made up a tentioner with a couple of rose joints you can just see it in this pic:
SB power all the way Ninja
Posted 3rd Jul 2010 at 04:00
rallyeash
Post #56
thanks for that! yeah mines a denso alternator aswell, now ive done the pulley ill prob just get a thinnner belt. yeah thats pretty much the same idea as ive got for the tensioner.
How's yours going btw? looked really good at an action day at combe last year i think, when i was having a nose around it.
interesting that you've put the catch tank over on the offside wing, where does the top pipe go to around the back of the block? i see the other two go across to the rockers and the big one as the drain back.
309 3dr K20 Type R
Posted 3rd Jul 2010 at 22:29
rallyeash
Post #57
indeedNinja
309 3dr K20 Type R
Posted 3rd Jul 2010 at 22:31
rallyeash
Post #58
rallyeash wrote:
indeedNinja
just got to fit the sticker now...Whistle
309 3dr K20 Type R
Posted 3rd Jul 2010 at 22:32
anth
Post #59
pete_rallye wrote:
anth wrote:
Reveries stuff is amazing had an air-box from them before, 2 min walk from me Big grin
You'll be able to blag some discount then! Whistle
Possibly,
A guy that works there got me an airbox for £50!
Although i havent spoken to him for a couple of years.
Posted 4th Jul 2010 at 00:50
dj_turbo
Post #60
Sandy recommended putting the tank there as some times they dont drain well on right handed circuits in the std gearbox position the top one is just a vent for the air presure.
When you getting it mapped? would be good to see this in action when its done as your local to me.
Mine is in bits diff or box went at llandow last month Sad still waiting to get the box back.
Posted 4th Jul 2010 at 03:08
rallyeash
Post #61
ah ok, hoping to get it mapped next month. need to get it over to maniflow to have the manifold made. did you have yours made there? and to sandys custom specs?
planning to take to the summer action day at combe, rally day and i'd like to do a shake down at an airfield day before the years out Smile
yeah your pretty local, im an area rep in hampshire so pretty much always that direction.
309 3dr K20 Type R
Posted 4th Jul 2010 at 23:07
309btcc
**DODGY SELLER**
Post #62
i had a maniflow on my 6 full btcc spec including manifold soundid awsome but cos £700 Owwwwccchhh
Posted 3rd Aug 2010 at 21:21
rallyeash
Post #63
still got it about?
309 3dr K20 Type R
Posted 3rd Aug 2010 at 21:39
309btcc
**DODGY SELLER**
Post #64
nope sold it mate when i wrote the car off sorry tannerman can get maniflow systems very cheap drop him a pm dude...
Posted 3rd Aug 2010 at 23:47
rallyeash
Post #65
aint updated this for ages couple of pics from today
309 3dr K20 Type R
Posted 6th Sep 2010 at 01:09
Post #66
Its not the most subtle front end i've ever seen, but it looks awesome Thumbs up LOL
Posted 6th Sep 2010 at 01:20
rallyeash
Post #67
haa, well it doenst sound subtle eitherNinja
looks quite mean i think, the grill will be fitted aswell which does tone it down abit trial fitted that earlier, front end wasnt bolted up proberly at the time
309 3dr K20 Type R
Posted 6th Sep 2010 at 01:26
rallyeash
Post #68
inside is starting to take shape
309 3dr K20 Type R
Posted 6th Sep 2010 at 01:27
tea boy
Post #69
rallyeash wrote:
you'd better get an air filter on there mate, it looks like you have sucked in a pair of scissorsBig grin
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 6th Sep 2010 at 04:27
cwspellowe
Post #70
They're used to create turbulence in the airflow, mixes the fuel and air better Wink
Bye bye Sundance Kid Sad
Posted 6th Sep 2010 at 04:29
spiky
Post #71
Yeah they really cut the air up
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 6th Sep 2010 at 12:06
rallyeash
Post #72
Roll eyes yes there will be a filter. just not top prioriy at the moment.Big grin
309 3dr K20 Type R
Posted 6th Sep 2010 at 12:29
will130787
Post #73
Badoom shh!
Cracking build though, very interesting thread! Wink
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 6th Sep 2010 at 22:02
309btcc
**DODGY SELLER**
Post #74
have you had it running then mate?/
Posted 7th Sep 2010 at 00:54
rallyeash
Post #75
No the loom needs altering to run the 8 injector setup, tps sensor connector on the loom need changing as on the old tb's i was running a 106 throttle pot and on the jenveys the connection is different.
i will be trailering it down to sandy browns in around 4 weeks to have these bits adapted, ill also let him run the engine up and map it.
im not really going to achive much running it myself, also i dont have a base map on the ecu for this engine. i would also rather let him run it up as will be in professional hands Smile
so all being well ill be picking it back up a couple of weeks later all mapped and ready for the motBig grin
309 3dr K20 Type R
Posted 7th Sep 2010 at 01:04
