Author Subject: Induction Mod
monkeyman
The standard induction system on the 306 is not bad, a lot better than most of todays shoehorned in as an afterthought cars, but the last pipe to the throttle is a bit of a compromise.
First it has to bend under the radiator pipe, then there is a concertina section to counter engine movement, and finally a t-piece to feed the idle, all add to air turbulence.
I wondered what difference a plain 90o aluminium pipe would make.
Pickup seems more eager 2.5 - 5k, feels the same higher up, but under 2k it looses a bit of torque, just need to blip the throttle before pulling away. I've got a straight centre pipe and Scorpion backbox, other exhausts will give slightly different results.
I got the parts from here -
http://www.auto-performance.co.uk/product_info.php?cPath=36_77&products_id=106
http://www.auto-performance.co.uk/product_info.php?cPath=21_53&products_id=635
http://www.auto-performance.co.uk/product_info.php?cPath=38_55_61_63&products_id=47
I had to take about this much off each end of the pipe -
You'll also need to make up an idle feed. I used a mini filter, a connector, and a bit of 5/8" radiator hose.
Notes -
I've got a Grp N lower and chocked upper mount, so my engine doesn't move much. The aluminium pipe works fine with this, but with standard engine mounts you will need to allow for some engine movement. A 90o sillicone hose, and some joiners might work, but I've not tried it.
I just measured the pipe by eye (as you can see) before cutting, and needed to cut one end twice. Cutting the pipe makes lots of aluminium dust and grains. You dont want these getting anywhere near your air filter or throttle, so give the pipe a good wash and dry before re-measuring/fitting it.
Fitting is a lot easier with the top radiator pipe unclipped. Make sure your engine has cooled down, and you've released the coolant pressure before undoing it.
Total cost was about £40.
Forum Search Clicky
Posted 15th May 2010 at 18:25
lewisdmz
Seems like a tidy little mod this, surprised it hasn't got more attention.
Posted 9th Feb 2011 at 23:25
rallyeash
because this is the easiest way to fill the engine up with water and bend conrods.
know this first hand...
309 3dr K20 Type R
Posted 9th Feb 2011 at 23:34
Only if you drive through rivers LOL
If you welded a T-piece into it near the top and put one of those little K&N style breather filters on, it would'nt be able to suck up any water. Does mean having the ability to ally weld. But would eliminate a potential problem and would'nt affect airflow in the slightest if done properly.
Posted 9th Feb 2011 at 23:40
rallyeash
wasn't me but a good mate, towed it back to my drive and ripped it all apart, even oval'd the crank!!
wasnt a river but a decent size puddle spreading across the road. was only a couple of inches deep
309 3dr K20 Type R
Posted 9th Feb 2011 at 23:46
daver6
Make a little drawing, I need an excuse to practice ally welding at work!
Wishbone Polybushes available
Posted 9th Feb 2011 at 23:48
smegal
From what I can see this uses the std airbox and snorkel so it won't suck up water.
Ex SC-6
Now in a Megane R26
Posted 9th Feb 2011 at 23:58
Just a junction for the filter to sit on, you give a relief path for the vacuum
Posted 10th Feb 2011 at 00:08
martinj
Exactly what I was thinking when looking at this thread, it is a smoother pipe from the standard air box to the throttle body rather than any change to the air inlet position....nice looking modification.
- Maxi rear axle hub spacers +53mm per side
- Maxi front steering rack extensions +40mm per side
Posted 10th Feb 2011 at 00:26
daver6
I might see what I've got on tomorrow. I'm hoping the Rottler's new motor has arrived so I can get my head skimmed!
Posted 10th Feb 2011 at 00:23
gtomi-6
im fitting my viper in my battery box and putting the battery in the rear. i think it should work very well/ of you sealed the battery box you could turn it into a giant air box, kinda like what longmans used on there btcc cars.
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 10th Feb 2011 at 00:40
lewisdmz
exactly lol.
Posted 10th Feb 2011 at 01:15
