I am probably to blame for all this bodge'ing
, as Rich said if you are standard then getting the original system to work correctly is the way to go, the only reason I bodged mine was I found the original system was a little slow getting my temperatures down due to my large fmic in the way of the airflow, I have now fooked off the original system altogether and use an aftermarket (Revotec) adjustable temperature controller/sensor which I have set to turn both fans on at high speed at 95 degrees, the only reason I have done this is because of the supercharger conversion and there is no need for this on a standard motor,
This setup works well on my car, pic of adjustable sensor in rad,
Team Supercharged Gti-6
