Author Subject: Gear Ratios, new Q! (Urgent-ish)
jepo
Sorry if this is on here somewhere already, but i had a quick look and couldn't come up with anything.
I'm after the 6 gear ratios as well as final drive ratio and all that jazz for the mighty '6.
Using figures from my car for an assignment i'm doing...except i don't know them! LOL
Any help or pointers as to where i can find them on the net would be great!
China Blue GTi-6 Yes
Posted 22nd Apr 2010 at 01:42
stu
1st - 2.92
2nd - 1.87
3rd - 1.41
4th - 1.15
5th - 0.95
6th - 0.80
Final Drive - 4.05
Thumbs up
I got them from a Spreadsheet someone posted up on here a while ago, AFAIK they are correct. Yes
Posted 21st Apr 2010 at 05:49
jepo
you sir, are a legend! haha, nah seriously thanks mate, that should do the trick. to be fair, it doesnt really matter if they're not right, i'm just quite fussy, wanted to use a '6 for my example so wanted the info to all be correct!
Posted 21st Apr 2010 at 07:01
3.95 f/d used as well, changed between p1-2, can't remember which was used when, but it says on servicebox.
Posted 21st Apr 2010 at 15:35
Any idea on a 406 coupe ML5T ratios?
Posted 21st Apr 2010 at 15:38
jepo
ok, more help if anyone could be so kind...
i haven't really had my '6 that long, and not driven it hard enough, often enough to really know the answer to this...i'm doing caclulations regarding the revs the car will be at in the next gear, if taking each gear through to the red (i'm using 7250 for the sake of my work)
just not sure my numbers seem right, but i don't actually know what revs it really drops to when going through the gears properly
I have (rounded of course):
2nd - 4650
3rd - 5410
4th - 5920
5th - 6000
6th - 6090
just seems like the last few are a touch high?
i thought it dropped to closer to 5k in each gear...
Posted 21st Apr 2010 at 22:42
jepo
BTTT! sorry about bumping, but wanna try and crack on with this tonight and i want to check my figures are at least half relastic before i continue!
Posted 22nd Apr 2010 at 01:41
They do look a tad high yes...
Posted 22nd Apr 2010 at 02:05
jepo
bugger.
that is all.
Posted 22nd Apr 2010 at 02:44
Rich E Forum Admin
The ratios Stu posted above are correct but have been rounded.
Assuming stock tyre size you will get the following:
Gearbox:- 306 GTi-6 Early FD
Tyre:- 195/55 x 15
Top Gear gives 21.567 MPH/1000 RPM and a top speed of 156.363 MPH at 7250 RPM
Engine speeds in top gear:-
30 MPH = 1391 RPM 40 MPH = 1855 RPM 50 MPH = 2318 RPM 60 MPH = 2782 RPM
70 MPH = 3246 RPM 80 MPH = 3709 RPM 90 MPH = 4173 RPM 100 MPH = 4637 RPM
Top Speed in 1 gear = 42.528 MPH
And changes into 2 gear at 4636 RPM dropping 2614 RPM
Top Speed in 2 gear = 66.511 MPH
And changes into 3 gear at 5485 RPM dropping 1765 RPM
Top Speed in 3 gear = 87.913 MPH
And changes into 4 gear at 5886 RPM dropping 1364 RPM
Top Speed in 4 gear = 108.282 MPH
And changes into 5 gear at 6006 RPM dropping 1244 RPM
Top Speed in 5 gear = 130.713 MPH
And changes into 6 gear at 6061 RPM dropping 1189 RPM
Top Speed in 6 gear = 156.363 MPH
Gearbox:- 306 GTi-6 Late FD
Tyre:- 195/55 x 15
Top Gear gives 21.008 MPH/1000 RPM and a top speed of 152.311 MPH at 7250 RPM
30 MPH = 1428 RPM 40 MPH = 1904 RPM 50 MPH = 2380 RPM 60 MPH = 2856 RPM
70 MPH = 3332 RPM 80 MPH = 3808 RPM 90 MPH = 4284 RPM 100 MPH = 4760 RPM
Top Speed in 1 gear = 41.426 MPH
Top Speed in 2 gear = 64.787 MPH
Top Speed in 3 gear = 85.634 MPH
Top Speed in 4 gear = 105.477 MPH
Top Speed in 5 gear = 127.326 MPH
Top Speed in 6 gear = 152.311 MPH
Posted 22nd Apr 2010 at 05:02
jepo
well well, Rich you're now owed some beer tokens!! not least because you're figures agree with mine, and the fact that a fair chunk of my assignment is right there in your post!! haha! Thumbs up
Posted 22nd Apr 2010 at 05:21
pugheaven
That is good info rich, do you know the figures for the xsara vts 5 speed box.
Would be good to see both figures side by side.
Ollie
Posted 22nd Apr 2010 at 22:38
Rich E Forum Admin
Here's the data for the Xsara VTS 'box. It's a little shorter geared than the GTi-6 'box overall with larger RPM drops on each shift apart from first to second.
The first and second gear ratios are the same in both 'boxes but the VTS 'box has a slightly shorter final drive ratio.
Gearbox:- Xsara VTS
Tyre:- 195/55 x 15
Top Gear gives 20.515 MPH/1000 RPM and a top speed of 148.732 MPH at 7250 RPM
30 MPH = 1462 RPM 40 MPH = 1950 RPM 50 MPH = 2437 RPM 60 MPH = 2925 RPM
70 MPH = 3412 RPM 80 MPH = 3900 RPM 90 MPH = 4387 RPM 100 MPH = 4875 RPM
Top Speed in 1 gear = 37.908 MPH
Top Speed in 2 gear = 59.286 MPH
And changes into 3 gear at 4965 RPM dropping 2285 RPM
Top Speed in 3 gear = 86.566 MPH
And changes into 4 gear at 5387 RPM dropping 1863 RPM
Top Speed in 4 gear = 116.514 MPH
And changes into 5 gear at 5680 RPM dropping 1570 RPM
Top Speed in 5 gear = 148.732 MPH
Posted 23rd Apr 2010 at 19:48
pugheaven
Thanks alot mate
Posted 23rd Apr 2010 at 19:55
