displaying posts 301 to 325 of 369
Pages (15): first .. 12 [13] 14 .. last
Author Subject: Ben306 rallye thread
ben306
Post #301
https://www.youtube.com/watch?v=svjURvxzjYs&t=5s
Few laps of 3 sisters last month.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 19th Aug 2022 at 08:35
ben306
Post #302
Few snaps from the latest track time last month at 3 sister
3 sisters circuit
Few laps at Blyton
Posted 19th Aug 2022 at 08:44
ben306
Post #303
And I've gone and picked up some Baker BM adjustable top mounts so hopefully now I'll be able to add a bit of camber up front and with my limited driving abilities, I might notice a difference!
Also picked up a set of 6 point harnesses (just out of date). Figuring that the current harnesses in the car are about 20-25 years old, it cant be a bad thing to replace them!
3 sisters circuit
Few laps at Blyton
Posted 19th Aug 2022 at 08:47
ben306
Post #304
Opentrack currently have a cheap day at Anglesey for Sat 3rd December which I've just booked £99, £89 with discount code. If anyone else fancies jumping on it?
Also looking at possibly Blyton end of October, and maybe 3 sister evening even next month as well.
3 sisters circuit
Few laps at Blyton
Posted 19th Aug 2022 at 10:05
ben306
Post #305
This is the type of washing I like on the line
Gave the new (to me) harnesses a clean and jet wash, although Im not planning to fit them any time soon
Also noticed that the back of the car was covered in wadding fibers after the last few trackdays so decided to cut open the middle box and re-pack it. Not my tidiest of welding but its done the job as there wasnt anything left in there
3 sisters circuit
Few laps at Blyton
Posted 30th Aug 2022 at 09:27
ben306
Post #306
And fitted the Baker BM adjustable top mounts, currently set to around negative 2.5 degrees, wants to pull you all over the place on the road.
Not really driven it properly to see as need to sort the alignment first but it feels completely different. I've purchased a tracking gauge so will try set it to parallel when that turns up. The true test will be the next lot of tracktime I suppose.
And there was a small local car show on this weekend so I popped down with it to rep the 306!
3 sisters circuit
Few laps at Blyton
Posted 30th Aug 2022 at 09:33
matty_rallye
Post #307
Made a big difference on mine. Running 3.5 degrees on the front currently. I wouldn’t worry about how it drives before you’ve done the tracking as it will be miles out after changing the camber.
2.1 16v 306 Rallye.
Posted 30th Aug 2022 at 21:05
ben306
Post #308
Well Im hoping the gauges should turn up early next week and I can get the thing running parallel. Then its an excuse to get tracktime to see the difference.
3 sisters circuit
Few laps at Blyton
Posted 31st Aug 2022 at 09:39
matty_rallye
Post #309
Get some camber gauges on there too just to make sure it’s set up perfectly.
We are at Combe on the 24th October but may be a bit of a way away?!
2.1 16v 306 Rallye.
Posted 31st Aug 2022 at 10:00
ben306
Post #310
So figured I'd sort the tracking out after fitting the new mounts.
Initial check wouldnt even register on the gauge, was about 4 degrees toe in
So aimed for parallel and some home brew string lines to measure and get the steering wheel pointing straight.
Bit of tweaking and got it pretty much bang on. Quick run out in it and it appears to be good.
3 sisters circuit
Few laps at Blyton
Posted 5th Sep 2022 at 08:31
Post #311
Good work mate. They're handly bits of kit those trackace's.
I took mine to the 'ring with me one year and somehow copped for the job of doing half our convoys tracking for them Laugh
Posted 5th Sep 2022 at 18:02
ben306
Post #312
Its paid for itself already so more than made up with it and its all pretty straight forward.
3 sisters circuit
Few laps at Blyton
Posted 31st Oct 2022 at 08:10
ben306
Post #313
Gone back to a standard disc as I wasnt happy with the way the drilled/grooved discs where chewing up the pads (I never liked drilled but they sent me the wrong ones and gave me a decent discount to keep them)
That was a track evening old M1155 pad. I've just gone to F6R pads with standard discs to try on the next few trackdays.
Also taken it to a few more local coffee morning type meets, surprising how much attention it gets
3 sisters circuit
Few laps at Blyton
Posted 31st Oct 2022 at 08:23
ben306
Post #314
Other than that, not really done much with it, just given it the once over as have a few Trackdays planned in the next few weeks.
Blyton on Saturday 12th November
Anglesey on Saturday 3rd December
If anyone wants to come join us I believe theres still spaces available for both
Only other thing I've done is since fitting the new top mounts, the strutbrace wouldnt fit and if it did it would have stopped me being able to get to any of the adjustable parts of the mount. So chopped it up, modified it, added some strengthening bits to the mounts, grinded the old paint off as it was rusting in parts, and gave it a quick brush with the good old hammerite (I'll do a proper job on it at some point later down the line.
3 sisters circuit
Few laps at Blyton
Posted 31st Oct 2022 at 08:21
ben306
Post #315
If anyone is bothered/bored/wants to kill 5 minutes.
Few laps from Anglesey at weekend
https://youtu.be/CiclEBp1iXE
3 sisters circuit
Few laps at Blyton
Posted 6th Dec 2022 at 07:27
ben306
Post #316
First time out proper with the rear hybrid ARB and 2.5 degree negative front camber set up. Definitely felt more planted, much better turn in, overall just felt to have more grip.
3 sisters circuit
Few laps at Blyton
Posted 6th Dec 2022 at 07:37
Joep
Post #317
Great feedback! I run a hybrid rear axle and baker bm topmounts as well. Did you set the camber based on the markings on the topmount?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 6th Dec 2022 at 09:38
ben306
Post #318
3 sisters circuit
Few laps at Blyton
Posted 6th Dec 2022 at 10:26
ben306
Post #319
I didn't use the markings as they were a little off on each side. I made myself a bit of a camber gauge and used that instead when I set up the tracking/alignment etc.
3 sisters circuit
Few laps at Blyton
Posted 6th Dec 2022 at 10:28
jord294
Post #320
I'm not a fan of hybrid arb. Served a purpose years ago pre axle rebuild. But now, would rather fit consistent 28.5 or 30mm arb
Posted 11th Dec 2022 at 18:58
ben306
Post #321
Came up cheap 2nd hand or Id have probably gone down the larger bar route.
Ideally I'd like to increase the torsion bar size as well (currently just on a 21mm) but again, I just see what/ if anything ever comes up for sale etc.
3 sisters circuit
Few laps at Blyton
Posted 12th Dec 2022 at 04:04
jord294
Post #322
Not much uprated stuff comes up 2nd hand tbh. We'll I've not seen anything for a while.
Even though I fitted it to my estate, 23s and 28.8mm arb coupled with b8s with h&r springs, worked exceptionally well. I think it's Martilus Laffin that has fitted similar to his rallye
Posted 13th Dec 2022 at 09:48
ben306
Post #323
Yeah, would be something along them lines that I'd probably want to go for eventually.
Quite happy with where I have got it to just now tho, all the small changes seem to keep getting it in the right direction and I still dont mind giving it a B road blast. Dont want to loose that really as you can get to the point where it becomes purely track.
3 sisters circuit
Few laps at Blyton
Posted 13th Dec 2022 at 16:37
rallyestyle
Post #324
Good to see that there is still interest in tweaking the 306 that's for sure.
While there isn't much uprated stuff that comes up for sale anymore i think there might be enough interested people to get some small runs on bespoke upgrades, wont be like the group buys of old but it could work.
One day i will finally get around to getting Andy (if he hasn't retired by then LOL) to build me a rear beam and hopefully that will have some upgraded tweaks to it.
Just Drive It
Posted 20th Dec 2022 at 09:48
ben306
Post #325
Theres still a dedicated few of us who sill appreciate these sheds LOL
Id much rather play in this than any of the modern stuff. yeah a little underpowered but its all good fun
3 sisters circuit
Few laps at Blyton
Posted 20th Dec 2022 at 11:18
