PS3 I.D - jenkers101Live i.d - Lukejenks1201
Author | Subject: My Rallye - V6 install page 3 |
![]() Seasoned Pro ![]() Location: Bristol Registered: 15 Mar 2008 Posts: 5,694 Status: Offline |
Post #76
Yes i may be useless but what did you want to ask about? ![]() ________________________________________ PS3 I.D - jenkers101Live i.d - Lukejenks1201 |
![]() Seasoned Pro ![]() Location: Co. Durham Registered: 12 Feb 2009 Posts: 2,401 Status: Offline |
Post #77
lukejenks101 wrote: ![]() Good to finally put a face to some of the regulars ________________________________________ Team 'unintentional rat look' |
![]() Seasoned Pro ![]() Location: Milton Keynes Registered: 22 Aug 2006 Posts: 5,525 Status: Offline |
Post #78
Good work lads, seems to be coming along nicely. ![]() Wish I had a workshop like that to play in. ![]() |
![]() Seasoned Pro ![]() Location: Bristol Registered: 10 Apr 2004 Posts: 26,784 Status: Offline |
Post #79
clen666 wrote: Good to finally put a face to some of the regulars Well most of my face is cambelt cover ![]() Adam cheers for the Subway lunch ![]() ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
![]() Yeeeah Rat fans! ![]() Location: Swansea Registered: 29 Nov 2006 Posts: 22,284 Status: Offline |
Post #80
Oi oi saveloy! ![]() |
![]() Seasoned Pro ![]() Location: The Nam Registered: 24 Jan 2006 Posts: 12,828 Status: Offline |
Post #81
You can't buy the old style cambelt setup from Peugeot now, just the new one that has to use a different water pump. Interestingly Peugeot are very nearly the cheapest for the clutch, but I'm getting a Gates Laguna/Clio belt kit off ebay for ________________________________________ Nothing to see here |
![]() Seasoned Pro ![]() Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
Post #82
Looking good Adam ![]() ![]() ________________________________________ Just Drive It |
![]() Capt Pedantic ![]() Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,852 Status: Offline |
Post #83
what price did Peugeot give you for the clutch? its ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #84
Its the same clutch but has an option to return your old one back to them. It was ________________________________________ Nothing to see here |
![]() Seasoned Pro ![]() Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,225 Status: Offline |
Post #85
Tesstuff got a gen pug later type cambelt kit of ebay cheap. Worth a look. Is that clutch inc discount? When I got a qoute for one last week it was more than that for a recon one ________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Post #86
Current Parts list:6x Plugs Inlet manifold gasket Crank oil seal (might as well) Flywheel (bolts + plate are the same as auto) Gearbox Gearbox mount + spike D9 Cambelt kit (belt + pulleys and tensioner) D9 water pump Coilpack bolts (muppets had rounded them off) Driveshafts Rear engine mount and driveshaft bearing Diff oil seals. Gearstick + cables Paul's ally top mount adapter plate Christ on a stick thats a lot of stuff ![]() ________________________________________ Nothing to see here |
Post #87
markrallye wrote: Tesstuff got a gen pug later type cambelt kit of ebay cheap. Worth a look. Is that clutch inc discount? When I got a qoute for one last week it was more than that for a recon one Mine is a dayco / INA cambelt kit from GSF. Worked out at ________________________________________ Nothing to see here |
Post #88
wooohhooo shiny shit to play with! ![]() shame the 306 is at the back of the unit, would have bought the pressure washer over to clean the engine and bay ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Post #89
Its not really a problem as I can squeegee it to the door anyway. In fact might get some of the other crap off the floor at the same time.Go get your car fixed you! ________________________________________ Nothing to see here |
Post #90
I may have missed it but what box are you using with it adam?________________________________________ Just Drive It |
![]() Moral objector ![]() Location: North London Registered: 11 Oct 2004 Posts: 10,399 Status: Offline |
Post #91
rallyestyle wrote: I may have missed it but what box are you using with it adam? +6 was just wondering the same thing.. ________________________________________ Democracy is two wolves and a lamb voting on what to have for lunch....Liberty is a well-armed lamb contesting the vote. Project é - my 306 project thread. |
Post #92
Its a coupe ML 5 speeder, not the auto ![]() ________________________________________ Nothing to see here |
Post #93
adam b wrote: Its a coupe ML 5 speeder, not the auto ![]() Good good, cant imagine an auto Rallye ![]() ________________________________________ Just Drive It |
Post #94
I'm not sure it would fit actually. Wouldn't have the clutch issue to sort ![]() ________________________________________ Nothing to see here |
![]() Seasoned Pro ![]() Location: Ringwood Registered: 28 Dec 2002 Posts: 3,433 Status: Offline |
Post #95
I do a hard rubber mount/bush for these, Has to be custom fitted thou due to the castings and cheap too________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
Post #96
Ok Miles, I may well be in touch.Having the flywheel looked at when it arrives to see if it needs skimming or can have any meat taken off easily without weakening it. Should have somewhere local to get the shafts done as well, will find that out later (there are a couple of options). Also trying to find out how much to advance the cams without causing any damage. Bit more torque wouldn't do any harm. Parts should be mostly all arriving tomorrow ![]() ________________________________________ Nothing to see here |
Post #97
No bloody post due to the snow, or deliveries into GSF. However Peugeot had everything bar one part and thats now having to come from France. Apparently not many people need V6 Gearbox mount parts ![]() ________________________________________ Nothing to see here |
Post #98
We need pics! ![]() |
Post #99
roland rat wrote: We need pics! ![]() +4.256789 ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Post #100
I will update this post as I weigh things...ML5 Gearbox - 50.5kg with selector fork GTi6 Gearbox - 40.2kg with selector fork GTi6 Inlet Manifold Complete - 9kg GTi6 Exhaust Manifold - 5.7kg V6 Inlet Manifold Complete - 6kg GTi6 engine with plugs, cambelt aux tensioners, PAS + alternator, flywheel and clutch (no wiring, most water hoses) - 145kg V6 - too heavy for the scales (over 150). V6 Standard Flywheel - 8.1kg (mine is expected to be about 7kg - safety first!) V6 Standard Clutch - 7.2kg Not easy to weigh the driveshafts but as standard I would say there is about 3kgs more on the V6 ones. Most of that is the outer cv joints. Mine are likely to be lighter as they will be a hybrid. ________________________________________ Nothing to see here |
