Do not confuse either with the low grade stud conversion sets that I wouldnt fit wheels to a shopping trolley with! If you do fast road driving, track days, circuit racing or rallying these are the ones for you. All studs and nuts are fully tested.
They come with radiused flange nuts with capitve washers so can be used with peugeot/citroen alloys. Also available are taper nuts for use with aftermarket alloys, compo, speedline etc.
There are two nut coatings available chrome coating and a dacromet finish. Both have good corrosion properties but the dacromet is a dull grey colour and chrome is shiney obviously. I have personally fitted the dacromet ones to my car for the sleeper look but know many of you will prefer the chrome oem look. As i have limited numbers it will be on a first come first served basis for coating choice.
Studs have a domed finish to aid nut starting and the threads on studs and nut are very good/clean.
(Apologies for poor picture quality)
Prices are as follows:-
Delivered to UK mainland & NI only. If your not covered by this then pm me for a quote for postage costs.
Taper nuts (set of 16) with following stud lengths:-
65mm =
