displaying posts 76 to 100 of 130
Pages (6): first .. 3 [4] 5 .. last
Author Subject: Max lift at TDC?
Post #76
Were you on stock or aftermarket pistons?
I'd imagine it was 1.4mm or more if it was a repair gasket, maybe even 1.6?
part number for that is 209 V4, but servicebox doesn't show the thickness Sad (I'm sure sandy knows anyway given he recommended!) not cheap compared to off the shelf gaskets!
Posted 3rd Aug 2010 at 21:44
rallyeash
Post #77
omega pistons
yes just found the old email. oversize XU7 J4 gasket, 0209 v4. circa £50 iirc
309 3dr K20 Type R
Posted 3rd Aug 2010 at 21:58
joevts
Post #78
for some reason i'm pretty sure the repair gaskets are 2.0mm, dunno where i got that from but i swear i didn't just make it up or hear it from some bloke down the pub LOL
Posted 4th Aug 2010 at 00:16
Post #79
not for a pug, seeing as the heads can;t be skimmed that much the stock are circa 1.2mm or so, repair 1.4 or thereabouts.
Posted 4th Aug 2010 at 00:19
gti-dan
Post #80
where you up to welshpug? Are you building it back up yourself? who is mapping? is it in yet? what cams are you using?
Posted 4th Aug 2010 at 03:18
Post #81
mine is all in one piece and running fine, apart from the pistons as mentioend I did it all myself.
Just a PH2 inlet cam, idles like a stock engine! as yet I'm not going to get it remapped, but will try and get it RR'd to make sure its not running lean, I would in future like to get a proper mappable ecu on there like a DTA S40 or similar.
not MOT'd or driven any further than ¼ of a mile yet I'm afraid, I have another car as a daily at the moment that I need to sell before I can afford to finish it properly.
Posted 4th Aug 2010 at 03:27
spiky
Post #82
Sorry to drag this up, does anyone have a rough idea how much would need to be machined off the pistons to get enough clearance, ( pockets)
Thanks
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 16th Mar 2011 at 01:32
Post #83
not specifically myself, you'd need to ask martin or colin or sandy Smile
Posted 16th Mar 2011 at 01:34
allanallen
Post #84
Thanks
Enough clearance for what? Any thing specific?
My pockets are are 1mm deeper than standard (same as welshpugs) and the heads had a 0.25mm skim. I'm currently running 1.3mm of lift at TDC. I'd be fairly confident running 2mm at TDC to be honest but I'm only on standard cams.
I don't think you'd want to go much deeper than 1mm on RS pistons.
Facebook
Posted 16th Mar 2011 at 02:07
discostu
Post #85
Hi, Spiky was replying to this thread on my behalf.. so thanks to him for that.
The situation is: i currently have my engine stripped down and also have acquired a pair of pt81's. Whilst the engine is in pieces i thought it best to get the pistons machined to insure valve/piston clearance.
i am currently trying to research (or work out myself) how much needs to be machined. All replies are welcome, thanks Smile
Posted 16th Mar 2011 at 02:58
Post #86
why not just send them to martin or colin? both are jigged up ready and have done all the calcs and checks already.
Posted 16th Mar 2011 at 03:33
discostu
Post #87
Fair comment Smile how is it best to contact either?
How are things with u welshpug, long time no spk. Building or driving anything exciting?
Posted 16th Mar 2011 at 03:39
Post #88
Martin by PM on here, username is CRF 450, or Colin is probably easiest to find via Sandy on the 205 forum!
at the moment been racking up the miles on my bike since new year after having my ZX bent by a micra Sad should be getting that straightened out soon then going to fit a DTA then if I can find one I want one of colins inlets Smile
205 has been sat neglected for a bit Sad
You still around Cwmbran?
Posted 16th Mar 2011 at 03:52
discostu
Post #89
Thanks i'll PM him tomorrow once i have collected my head.
Yes still living in Cwmbran, in Oakfield... not too far from the chinese takeaway and the pub, perfect lol
Posted 16th Mar 2011 at 04:21
Post #90
Thought I'd add the Catcams figures for their fast road cams:
4903106
duration @ [0.1mm+cl] 267 / 259°
duration @ [1.0mm+cl] 228 / 224°
Peak lift 10.95 / 10.40mm
Lift @ TDC 1.25 / 1.05mm
Seem to have been thought out to work in a standard engine, though without seeing the curve of the profile its hard to compare properly, but they should give similar results to PT81's etc.
Though having spoken to Sandy about cams I'd be using Piper or Newmans, he wasn't keen on how catcams design their ramp angles etc with regards to component life as he has had issues withthem.
Posted 29th Apr 2012 at 21:23
spiky
Post #91
Would be nice to know if they will fit to abstain pocketed pistons Smile
MY YouTube Videos'
Posted 29th Apr 2012 at 21:24
Post #92
I would think they should be ok as long as the head had not been skimmed, or if it had that the seats were cut back.
They're the cams that pug1off are using in standard engines for their "195" conversion.
Posted 29th Apr 2012 at 21:28
matty_rallye
Post #93
Yes Worn lobes on my Catcams after a few thousand miles!
2.1 16v 306 Rallye.
Posted 29th Apr 2012 at 21:39
Post #94
Surely thats down to poor bedding in procedure or insufficient cam lube on initial startup? Were they used lifters on a new cam? As thats a massive no-no.
Posted 30th Apr 2012 at 18:12
Post #95
"I live my life a 1/4 mile at a time" Laugh my ass off
Posted 30th Apr 2012 at 18:15
Post #96
Laugh my ass off the car's done 6k miles and been bent a bit a few times since then Doh
Posted 30th Apr 2012 at 19:19
paulvancraen
Post #97
Did you pocket the RFY or the RFS pistons in your build Welshpug? And how deep did you pocket them?
Paul
Posted 2nd May 2012 at 12:51
allanallen
Post #98
Paul
RFS pistons with the pockets machined 1mm deeper. You can't go much deeper as RFS piston crowns are very thin.
Facebook
Posted 2nd May 2012 at 13:22
paulvancraen
Post #99
How about RFY pistons? Are they thicker?
I'm thinking about using the complete RFY bottom end and pocket these pistons. Then slap the RS head on it Smile
Posted 2nd May 2012 at 14:03
Post #100
RFY would not need the pockets modifying at all, they are much deeper, however they are a fair bit heavier and the rods are shorter on them meaning a sharper angle mid stroke.
Posted 3rd May 2012 at 18:00
