displaying posts 26 to 50 of 130
Pages (6): 1 [2] 3 .. last
Author Subject: Max lift at TDC?
dan gti-6
Im unsure on prices to be honest but will find out tomorrow and report back!
Yeah ideally you want aftermarket piston so you can raise the CR as well as gaining valve clearance.
I just got the impression from the first page that you wanted to build an engine properly but on a budget, which is fine ive been thinking about building an 88mm lump for a while!
Bear in mind pistons are about
Posted 20th May 2009 at 23:13
Well so far from the bits I've got I can build an engine with a 10.9 compression ratio, or if I get hold of an 88mm crank 13-1 LOL
The actual parts have cost me about
Posted 20th May 2009 at 23:38
matty_rallye
An alternative is to have Nissan pistons machined (see pic) and fitted which is what Sandy fitted into mine. 87mm though so block will need to be bored.
2.1 16v 306 Rallye.
Posted 21st May 2009 at 00:36
dan gti-6
What pistons are they exactly?
I rebore alot of nissan blocks at work and flat top RB25 (GTS) pistons look similar to 6 ones, although i havent got round to measuring either up yet!
Posted 21st May 2009 at 04:10
RB25 is 86mm though?
Doh of course they aren't after a rebore LOL
Posted 21st May 2009 at 04:17
matty_rallye
N/A 300zx pistons!
2.1 16v 306 Rallye.
Posted 21st May 2009 at 23:39
vts_tibi
I have a Peter Taylor stg.1 inlet camshaft, and I would be curious what you guys think about it's specs. :
"Duration 226 deg. @ 0.050"
Max. Lift 0.350"
Lift @ TDC - 0.065" (but a range of 0.065-0.075 is acceptable for fine tuning)"
It's a regrind from an XU10J4R camshaft to stg.1 XU10J4RS spec.
VTS
best 60' : 2.272
Team Trackday™
Posted 22nd May 2009 at 15:38
sandy
matty_rallye wrote:
N/A 300zx pistons!
It was far too much work, I'm not in a hurry to do that again!
Posted 23rd May 2009 at 13:19
mark-house
So to fit some uprated cams and to have safe clearance at TDC what pistons are required? Im assuming some forged aftermarket ones but does anyone know who makes them?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 26th May 2009 at 17:52
Post #35
Wossner, Accralite, Omega, JE, Arias, Cosworth Mahle and many many others.
Posted 26th May 2009 at 18:07
o_tateuk
Post #36
F**k im taking my cams out! LOL
Ex team china wish i hadnt done it but oh well.
Now saving up the dollas for a nice bianca rallye! May the search commence!!!!
205 1.8 Derv! (The work run slag) Big grin
2nd 205 but with D-Turbo power! Big grin
Posted 3rd Jun 2009 at 04:18
chris with a pug
Post #37
where do you work?
Posted 3rd Jun 2009 at 05:31
Post #38
i can remember the thread a while back with the guy having so much trouble with fitting pt82`s(i think).
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th Jul 2009 at 14:06
Post #39
now you know why!
Posted 9th Jul 2009 at 15:59
Post #40
Max. Lift 0.350"
I forgot to post the details I had got from Newmans on their PH2-
quote:
Hi There,
Lift @ TDC is 1.14mm,
Duration @ 1.0mm is 222.5 Degrees,
Duration @ 0.1mm is 256,
Duration @ 0.0762mm is 264 Degrees.
Regards,
Ken Newman
quite difficult to compare what with the metric and imperial measurement mix used Doh
Posted 16th Dec 2009 at 17:10
Post #41
Have you worked out the cc of the engine you are considering then Mei?
I was wondering about getting a couple of PeterT's cams ages ago, but decided i'd get more from making the chassis and brakes good. Your ZX is hardly slow as it is Smile
Posted 16th Dec 2009 at 18:05
petert
Post #42
Not really, eg
1.14mm = 0.045"
my cam has 0.065" at TDC, thus the inlet valve is opened earlier (given the same centreline)
PH2 : 222.5 @ 1mm
My Mi16 Stage I 16H426B : 234 deg @ 1mm
so is significantly bigger and would definitely be a candidate for smashing valves into pistons if not setup correctly. Magic used it and got some very impressive hp figures.
Posted 17th Dec 2009 at 09:56
vts_tibi
Post #43
at which angle does my camshaft have 1mm lift Peter?
Max. Lift 0.350"
Lift @ TDC - 0.065
VTS
best 60' : 2.272
Team Trackday™
Posted 17th Dec 2009 at 18:09
Post #44
I was meaning the difference in duration, i.e you measure your cam at 0.050" which is 1.27mm, giving 226 deg.
Newmans measure at 1mm. and give 222.5mm.
what does your gti6 cam give at 1.0mm/0.0393"?
I might be interested in sending an XU10J4R or XU7 cam, or even a J4RS cam for a stage 1 grind, the results you and Magic have got from them are quite impressive I mus say Smile
Adam the engine I considered putting toge3ther would have ended up at either still at 1998 cc on the standard crank but with 2.0 RFY mi16/s16 pistons and rods and 10.9-1 compression or using a 1.9 88mm crank for 2044cc, that would need some piston skiming or a thicker gasket, or some chamber relief work as it'd give a 13-1 compression as is Shock
Posted 18th Dec 2009 at 03:01
Post #45
Yes I got it after you explained it earlier! Interesting thread this Ninja
Posted 18th Dec 2009 at 04:21
Post #46
very interesting once more, as my headgasket has died Sad Doh
anyone know where and how much it'd cost to have the cutouts made a little deeper?
Posted 7th Jan 2010 at 04:11
allanallen
Post #47
Pm martin (crf450), I believe hes done a few sets now
Facebook
Posted 7th Jan 2010 at 14:04
Post #48
Is this standard pistons?
Posted 7th Jan 2010 at 14:05
Post #49
yes Mr Harris, would enable you to run cams like PT81's or PT82's etc without fear of bending valves.
Allanallen, thanks for the tip I'll PM him now, AdamB got a price from the machine shop a few doors down from him, initial setup cost was quite a bit but gets cheaper and cheaper the more sets are done.
I "think" sandy can sort them too so I'll ask him as well.
I'm going to see how much extra room is needed for the first step or two in cam upgrades, generally these don't need uprated pistons I dont think.
Posted 8th Jan 2010 at 01:07
mxcrazy
Post #50
I am too pondering on cam shafts at the moment, i think with the pistons i have that i will be able to have some fairly large max lift figures, the cut outs are reasonably large. But, i dont want to have to rev this thing real hard to get the power from it.
Welshpug, i have the drawings of these pistons ive got, do you want a look? ill have to email them over.
Posted 8th Jan 2010 at 01:19
