Author Subject: ECU unlocking
bulldogs
How much would it cost to unlock an ecuUnsure
Posted 15th Mar 2009 at 22:24
khj100
How.....
...much effort would it take to give your thread a meaningful title and post in the right forum?
Anyway, it's probably around
Posted 15th Mar 2009 at 22:25
bulldogs
Sorry khj ,im at a loose end now and losing faith with this carWink
Posted 15th Mar 2009 at 22:33
mechanical_repairs
I can supply you one professionally done so will never give you greif for
Posted 15th Mar 2009 at 22:42
beez_neez_gt
Thread resurrection i know.
Whats the real difference to that then ?
Also does the ECU have to be the original one from the original car when doing the ignition on and unplugging procedure ?
Cheers.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 30th Jul 2010 at 04:38
bear in mind it'll relock if you put it back into another 306 though which has the immobiliser function so you need to either chop the immobilsing pins off the loom or put it into a car where it won't relock
Posted 30th Jul 2010 at 04:43
beez_neez_gt
Like the 205 conversion, i know that putting it in another 306 the immobiliser will lock again, i'm just wondering if any 306 Ecu's apart from the PH1 can be unlocked from any other 306 gti6 ?
Pug fee`ver,
Posted 30th Jul 2010 at 04:50
if you have all the bits yeah.
Posted 30th Jul 2010 at 13:48
beez_neez_gt
Thanks WP, what do you mean by 'bits' ?
Pug fee`ver,
Posted 30th Jul 2010 at 16:36
ecu, transponder unit and chip (inside key foCool.
Posted 30th Jul 2010 at 21:55
beez_neez_gt
I have a 306 6 car, its key fob for it,its original ecu for it, not sure what a transponder is ?? and i have an unlocked 6 ecu needing unlocked cheap by myself. Will i be able to with this lot ? Or do i need the locked ECUs original key fob and transponder to do it ? I thought i just needed to pull the ecu away when ignition is on then its ready for a 205 and not for the 306 ?
Pug fee`ver,
Posted 30th Jul 2010 at 22:06
ryanmt
You can unlock most the ecus by yoinking the ecu off the car with the engine running. It will relock as soon as its reconnected to a car with the transponder fitted though.
Failing that if its a none runner I can unlock the ecus too.
Pretty much all ecus can be unlocked manually, some are easier... some are a nightmare (the sagem ones that are filled with resin goo!)
Posted 1st Aug 2010 at 21:45
beez_neez_gt
Ok thanks, i have a locked ecu for my 205 conversion, so ill just use my 6 to unlock it and hope it works.
Cheers.
Pug fee`ver,
Posted 1st Aug 2010 at 21:51
ryanmt
Youll need the matching transponder box / key with chip from the car your ecu came from to start the car.. from there you can unlock it. Without the missing bits youll need to send it off somewhere Smile
Posted 1st Aug 2010 at 22:03
beez_neez_gt
Right ok then, but i only need to turn the ignition on then unplug the ecu for it to be unlocked yeah ?
Pug fee`ver,
Posted 1st Aug 2010 at 22:15
ryanmt
Ok, say you have a fully functioning gti6 and you want to use it to unlock an ecu.
1) Fit the ecu you want to unlock
2) Fit the transponder box that goes under the dash that matches the ecu
3) Remove the transponder pickup ring from the barrel but leave the electrics connected.
4) Put the key that matches the ecu inside the barrel.
5) use the usual car key to start the car, the ecu, trasponder and fob inside the pickup ring are all matching so the car will start
6) Disconnect either the transponder or the ecu, it doesnt matter. With the engine running.
7) The ecu is now unlocked. Reconnecting the ecu on a car that has a transponder fitted will relock it, so dont do this.
Hope that cleared it up Smile
Posted 2nd Aug 2010 at 05:52
beez_neez_gt
Very much so yeah, thanks Smile.
Pug fee`ver,
Posted 2nd Aug 2010 at 06:49
